On the top navigation bar, click Cloud Services, and then select Security Groups from the Network menu.
Click a security group name.
Click the Inbound Security Group Rules or Outbound Security Group Rules tab, and then click Create.
Configure security group parameters as described in Table-1.
Click OK.
Table-1 Configuring security group parameters
Parameter |
Protocol Type |
Select a protocol to which the security group rule will apply. |
Direction |
Select a traffic direction.
Port Range |
Enter a port number range. If you select a protocol that uses a fixed port, do not configure this parameter. |
Peer Address |
Select a peer type. |
IP Version/Authorization Object/Security Group |
For a peer IP address or network |
IPv4 |
Permit an IPv4 address or address range. |
IPv6 |
Permit an IPv6 address or address range. |
For a peer security group |
IPv4 |
Permit the IPv4 cloud hosts in a security group. |
IPv6 |
Permit the IPv6 cloud hosts in a security group. |
