Select an existing
organization for the security group. A system administrator can select any
organization. An organization administrator or user can select only an organization
to which the organization administrator or user belongs. The selection
affects the owner's range of selection.
If a user
belongs to multiple organizations, click the icon
on the right side of the admin icon, select Change
Organization, and then select the target organization. The role of the
user might change after you change the organization.
