On the top navigation bar, click Cloud Services, and then select Load Balancing from the Network menu.
Click a load balancer name.
Click the Real Server Groups tab.
Click Details in the Health Check column for a real server group. If the real server group is configured with no health check monitor, the Health Check column is empty.
Click More Actions for a real server group, and then click Create Health Check Monitor.
Configure health check parameters as described in Table-3.
When you configure health check parameters, use the restrictions and guidelines in "Restrictions and guidelines."
Click OK.
Click More Actions for a real server group, and then click Edit Health Check.
Edit health check parameters as described in Table-3.
When you edit health check parameters, use the restrictions and guidelines in "Restrictions and guidelines."
Click OK.
Click More Actions for a real server group, and then click Delate Health Check Monitor.
