On the top navigation bar, click Cloud Services, and then select Load Balancing from the Network menu.
Click a load balancer name.
Click the Real Server Groups tab to view real server group information.
Click the Real Server Groups tab.
Click Create.
Configure real server group parameters as described in Table-2.
When you configure real server group parameters, use the restrictions and guidelines in "Restrictions and guidelines."
Click OK.
Click Edit for a real server group.
Edit real server group parameters as described in Table-2.
When you edit real server group parameters, use the restrictions and guidelines in "Restrictions and guidelines."
Click OK.
Click Delete in the Actions column for a real server group. To delete multiple real servers in bulk, select the target real servers, and then click Delete.
