MCP cluster list
The MCP cluster list displays the MCP clusters with applications deployed. You can view the brief information about an MCP cluster and its deployed applications, and go to the container cluster list to view clusters by application. To view the detailed information about an MCP cluster, click its name. For more information about MCP clusters, see "Cluster management in a multi-cloud environment."
