On the top navigation bar, click Business Apps.
From the left navigation pane, select Delivery Center > Continuous Delivery.
Select ConfigMap Management > Quality Gates.
Click a quality gate name to view the quality gate details.
Conditions: Quality gate conditions on unit test, API test, and code review.
Usage Statistics: Statistics on the quality gate usages in pipelines, including the number of checks, number of interceptions, and number of passes.
Click Add to add a quality gate.
Configure the quality gate parameters and then click OK.
Parameter |
Name |
Name of the quality gate. Supported characters are Chinese characters, letters, digits, and special characters (.-_). The name must start with a Chinese character or a letter and cannot exceed 100 characters. |
Description for the quality gate. |
Conditions |
Quality gate conditions: Unit Test Pass Rate: 0 to 100, in percentage. |
Code Review
API Test Pass Rate: 1 to 100, in percentage. |
Perform this task to apply a quality gate to one or more pipelines where no quality gate has been used. To change the quality gate for a pipeline, see "Orchestrate a pipeline."
Click Apply in the Actions column for a quality gate.
Select one or multiple pipelines.
You can filter pipelines by name.
Click OK.
The quality gate is applied to the selected pipelines.
The changes of a quality gate automatically apply to all pipelines that have used the quality gate. Use caution when you perform the edit operation. |
Click Edit in the Actions column for a quality gate.
Configure the parameters as needed.
Click OK.
Perform this task to copy a quality gate, and then edit the copied settings to create a new quality gate as needed.
Click Copy in the Actions column for a quality gate.
Edit the quality gate settings as needed.
Click OK.
Quality gates that have been applied to pipelines cannot be deleted.
Click Delete in the Actions column for a quality gate.
