During bare metal node deployment, the system will send bare metal resource information to the Nova database after you prepare the bare metal nodes for assignment. To avoid deployment failure, wait for a minimum of two minutes after you prepare the bare metal nodes for assignment. |
On the top navigation bar, click Resources.
From the left navigation panel, select Bare Metal.
Select one or multiple bare metal nodes, and then click Deploy.
The node must be in assignable state.
