On the top navigation bar, click System.
From the left navigation pane, select System Settings > Security Settings > OAuth2.0.
Click Create.
Configure the OAuth 2.0 service parameters.
Table-1 Configuring OAuth 2.0 service parameters
Parameter |
Redirect URLs |
Enter the address of the third-party application to be redirected to. To enter multiple addresses, separate them with commas (,). |
Logout Redirect URL |
Configure the logout redirect URLs. When a user logs out of a system, the user will automatically logs out of the systems that specified by the logout redirect URLs. This feature must be configured together with "OPENID." |
Click OK.
You can obtain the client ID, client secret, and Discovery Url in the list.
