Configure the encryption module according to the manufacturer's instructions and ensure the network connectivity between the encryption module and the system.
Obtain the IP address and port information of the encryption module in advance.
Figure-1 Configuration flow
Table-1 Configuration flow
Task |
Install cloud service installation package and components |
Upload and deploy corresponding cloud service installation package and components in advance. For more information, see "Configure cloud services and system components." |
Create a public key certificate provided by the manufacturer in the system in advance. |
Configure INFOSEC encryption module. |
Obtain the public key certificate file provided by the third-party manufacturer of the encryption module in advance. |
On the top navigation bar, click System.
From the left navigation pane, select System Settings > Security Settings > Public Key Certificate.
Click Create Public Key Certificate. Configure public key certificate parameters.
Table-2 Configuring public key certificate parameters
Parameter |
Certificate Name |
Specify the name of the customized certificate. |
Public Key Subject |
Specify the subject of the public key certificate. |
Public Key Certificate |
Enter the public key certificate. |
Click OK.
From the left navigation pane, select System Settings > Security Settings > Encryption Module Settings.
Click Create Encryption Module Settings. Configure parameters for the encryption module.
Click Test Connectivity to test the connectivity of the encryption module.
Table-3 Configuring encryption module parameters
Parameter |
Platform Name |
Specify the name of the encryption platform. |
appId |
Enter the App ID obtained from the manufacturer. |
SecretKey |
Enter the secret key obtained from the manufacturer. |
IP/Port |
Enter the obtained encryption module IP or port. |
Protocol |
HTTP protocol is supported. |
Select the target public key certificate. Click Edit. Configure public key certificate parameters.
Click OK.
Select the target public key certificate. Click Enable.
Click OK.
Deleting public key certificates will make corresponding users unable to log in normally. Perform this operation with caution. |
Select the target public key certificate. Click Delete.
