Configure the encryption module according to the manufacturer's instructions and ensure the network connectivity between the encryption module and the system.
Obtain the certificate chain from the CA in advance, and use the certificate chain to obtain the IP address and port information of the encryption module.
On the top navigation bar, click System.
From the left navigation pane, select System Settings > Security Settings > Encryption Module Settings.
Configure parameters for the encryption module. Click Save Configuration or Edit.
Table-1 Configuring encryption module parameters
Parameter |
Encryption Module IP/Port |
Enter the obtained encryption module IP or port. |
Encryption Key |
Set the encryption key for encryption as required by the manufacturer. |
Encryption Module Manufacturer |
Specify the encryption module manufacturer as DA. |
