The NIC bonding, NIC quantity, and system disk settings configured when creating or requesting a bare metal instance must be the same as those configured in this section. For other parameters, the most recent configuration takes effect, no matter whether they are configured in configuring a bare metal node or bare metal instance.
On the top navigation bar, click Resources.
From the left navigation pane, select Bare Metal.
Select a bare metal node, click Actions on the top of the node list, and then select Node Settings.
Configure node settings.
You can configure bare metal nodes in manageable state only.
