The bare metal server will be restarted after you start discovering a bare metal node. Make sure no imported services on the server are affected. |
On the top navigation bar, click Resources.
From the left navigation pane, select Bare Metal.
Select a bare metal node, click Actions on the top of the node list, and then select Start Detection. The node must be in manageable state.
