Create a network
  1. On the top navigation bar, click Cloud Services, and then select Classic Networks or VPCs from the Network menu.
  1. On the Classic Networks page, click Create. To create a subnet for a network, select Create Subnet.
  1. If you select VPCs from the Network menu, select Private Networks from the left navigation pane, and then click Create.
