Create a compute AZ
Create a compute AZ
  1. Click Resources on the top navigation bar.
  1. On the Compute AZs page, click Create.
  1. Configure compute AZ parameters as required:
  1. Select BareMetal from the Hypervisor list.
  1. Select New AZ from Creation Mode.
  1. Configure other parameters by referring to Create a compute AZ.
  1. Click OK.
Assign an AZ to an organization
  1. On the top navigation bar, click System.
  1. From the left navigation pane, select Organization Management.
  1. Select an organization, click the Quotas tab, and then click Edit.
  1. Select the AZ you created in the Basic Info area, and then click OK.
