On the top navigation bar, click Cloud Services, and then select Cloud Network Disks from the Storage menu.
From the left navigation pane, select Advanced Settings.
Click Edit and configure the following parameters as needed.
IP Address—Management IP address of AnyShare.
App ID.
App Key.
