Perform this task to view basic information, API request information, and back-end request information about an API.
On the top navigation bar, click Cloud Services, and then select Service Gateways from the App Service menu.
From the left navigation pane, select Service Release > API Group Management.
Select a service gateway from the service gateway filter list.
Click the name of a service gateway.
Click the name of an API to view detailed API information.
API Info
Basic Info—Contains API group, access control policy, authentication policy, and request throttling policy.
API Request Info—Contains the request protocol, request method, and request path.
Back-End Request Info—Contains the request protocol, request method, backend service type, retries, and timeout time, load balancing algorithm, back-end service, default version, and features.
API Monitoring—Contains the numbers of requests and errors, data, and call latency for the API.
Authentication Info—Contains authentication type and authentication policy. For an AK/SK or JWT authentication policy, the subscribed credentials are also displayed.
Version Info—Allows you to perform version management.
Load balancing policies for different APIs do not affect each other. |
From the left navigation pane, select Service Release > API Management.
Click Version Management in the Actions column for an API. Alternatively, click the name of an API, and then click the Version Info tab.
Click Add Version, and then configure the parameters as needed.
Click OK.
If you configure a version as the default version, the request where the header does not contain an API version will be forwarded to the back-end service address specified in that version.
Click Set as Default Version in the Actions column for a version.
In the dialog box that opens, click OK.
Click Edit in the Actions column for a version.
Click OK.
A default version cannot be deleted. |
Click Delete in the Actions column for a version.
If an API has been subscribed by a consumer, the API publisher can freeze or unfreeze a credential to control access of the consumer to the API.
Click the name of an API, and then click the Authentication Info tab.
Click Freeze in the Actions column for a credential.
To unfreeze the credential, click Unfreeze.
A disabled API will not be available to any applications or users. When you disable an API, make sure you fully understand the impact of the action on services. |
Click Enable or Disable in the Actions column for an API to enable or disable it.
Perform this task to edit API information, including basic information, back-end service, API request parameters, and policies.
Click Edit in the Actions column for an API.
Edit API parameters. For information about API parameters, see "Publish an API."
To change a policy, click Unbind for that policy, select a new policy, and then click Bind.
Click OK.
Perform this task to delete an API permanently.
When you delete an API, make sure you fully understand the impact of the action on services. The API will be unavailable after it is deleted. In addition, all its data will also be automatically deleted and cannot be recovered. |
Click Delete in the Actions column for an API.
Click OK.
Click OK.
