View detailed information about an application package
Perform this task to view detailed information about an application package, for example, version, used space, category, and description.
  1. On the top navigation bar, click Business Apps.
  1. From the left navigation pane, select Software Center > App Repositories.
  1. Click the Private Repository or Public Repository tab.
  1. Click the name of an application package to view its information.
  1. To publish, deploy, download, edit, or delete an application package version, click the target link in the Actions column for that version.
