Create a security group
  • By default, a created security group denies all inbound traffic and permits all outbound traffic. You can configure rules for the group to permit specific traffic.
  • After you create a cloud host, you can change the bound security group.
  • To access a cloud host through SSH, you must configure security group rules for the inbound direction to permit traffic from the local PC to the cloud host. For more information, see "About security groups."
  1. On the top navigation bar, click Cloud Services, and then select Security Groups from the Network menu.
  1. Click Create.
Figure-1 Creating a security group
  1. Specify the group name and description.
  1. Click OK.
  1. Click the name of the created security group.
  1. Click Create on the Inbound Security Group Rules or Outbound Security Group Rules tab.
Figure-2 Creating an inbound security group rule
  1. Configure rule parameters as needed and click OK to submit a rule configuration.
Table-1 Configuring a security group rule
Parameter
Protocol Type
Specify the permitted protocol.
Direction
Displays the traffic direction. Inbound represents traffic sent to cloud hosts and outbound represents traffic sent from cloud hosts.
Port Range
Specify the range of permitted destination port numbers. This field is unavailable if the permitted protocol uses a fixed port.
Peer Address
Specify the IP permitted object type. Options include IP Address/Network Address and Security Groups.
IP Protocol Type
Specify the permitted IP protocol version. Options include IPv4 and IPv6.
Authorization Object
Specify the permitted IP address or network segment. This field is available only when the Peer Address field is IP Address/Network Address.
Security Groups
Specify the permitted security group. This field is available only when the Peer Address field is Security Groups.
