CLI example: Using a user-defined IPS policy in a security policy
As shown in Figure 1, the device connects to the LAN and Internet through security zones Trust and Untrust, respectively.
Perform the following tasks:
Create IPS policy ips1 and modify its signature action and status settings as follows:
Apply IPS policy ips1 to the zone pair between source security zone Trust and destination security zone Untrust.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9071 of the M9000-AI-E8 device.
Procedures
1.        Assign IP addresses to interfaces:
# Assign an IP address to interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] ip address 192.168.1.1 255.255.255.0
2.        Configure settings for routing.
This example configures a static route to reach the Web server, and the next hop in the route is 2.2.2.2.
[Device] ip route-static 5.5.5.0 24 2.2.2.2
3.        Add interfaces to security zones.
[Device] security-zone name trust
[Device-security-zone-Trust] import interface gigabitethernet 1/0/1
[Device] security-zone name untrust
[Device-security-zone-Untrust] import interface gigabitethernet 1/0/2
[Device-security-zone-Untrust] quit
4.        Configure an IPS policy:
# Create an IPS policy named ips1 and enter its view. Configure the IPS policy to use all IPS signatures without discrimination of the target attribute. Enable predefined IPS signature 2 and specify actions drop, capture, and logging for the signature, disable predefined IPS signature 4, and enable predefined IPS signature 6.
[Device] ips policy ips1
[Device-ips-policy-ips1] protect-target all
[Device-ips-policy-ips1] signature override pre-defined 2 enable drop capture logging
[Device-ips-policy-ips1] signature override pre-defined 4 disable
[Device-ips-policy-ips1] signature override pre-defined 6 enable
[Device-ips-policy-ips1] quit
5.        Apply IPS policy ips1 to a DPI application profile, and activate the IPS policy settings:
# Create a DPI application profile named sec. Apply IPS policy ips1 to the DPI application profile and set the policy mode to protect.
[Device] app-profile sec
[Device-app-profile-sec] ips apply policy ips1 mode protect
[Device-app-profile-sec] quit
# Activate the IPS policy settings.
[Device] inspect activate
6.        Configure a security policy:
# Enter IPv4 security policy view. Create a rule named trust-untrust to permit the traffic from internal users to the external network and apply the IPS policy to the traffic between the internal users and the Internet.
[Device] security-policy ip
[Device-security-policy-ip] rule name trust-untrust
[Device-security-policy-ip-10-trust-untrust] source-zone trust
[Device-security-policy-ip-10-trust-untrust] source-ip-subnet 192.168.1.0 24
[Device-security-policy-ip-10-trust-untrust] destination-zone untrust
[Device-security-policy-ip-10-trust-untrust] action pass
[Device-security-policy-ip-10-trust-untrust] profile sec
[Device-security-policy-ip-10-trust-untrust] quit
# Activate rule matching acceleration.
[Device-security-policy-ip] accelerate enhanced enable
[Device-security-policy-ip] quit
# Verify that IPS policy ips1 is configured correctly.
<Device> display ips policy ips1
Configuration files
 port link-mode route
 ip address 2.2.2.1 255.255.255.0
security-zone name Trust
 import interface GigabitEthernet1/0/1
security-zone name Untrust
 import interface GigabitEthernet1/0/2
app-profile sec
security-policy ip
 rule 10 name trust-untrust
  action pass
  profile sec
  source-zone trust
  source-ip-subnet 192.168.1.0 255.255.255.0
ips policy ips1
 signature override pre-defined 2 enable drop logging capture
 protect-target ApplicationSoftware IM
 protect-target ApplicationSoftware MailClient
 protect-target Browser InternetExplorer
 protect-target Database ACCESS
 protect-target Database MS-SQL
 protect-target Database MySQL
 protect-target Database Oracle
 protect-target Database Other
 protect-target FTPServer Any
 protect-target MailServer LotusNotes
 protect-target NetworkDevice Cisco
 protect-target NetworkProtocol FTP
 protect-target NetworkProtocol HTTP
 protect-target NetworkProtocol TELNET
 protect-target OfficeSoftware MicrosoftOffice
 protect-target Other Other
 protect-target WebApplication Any
 protect-target WebApplication Blog
 protect-target WebApplication CMS
 protect-target WebApplication JSP
 protect-target WebApplication Other
 protect-target WebApplication PHP
 protect-target WebServer Any
 protect-target WebServer Other
 protect-target WebServer WebLogic
