CLI example: Configuring Telnet login
As shown in Figure 1, the device allows Telnet login only from hosts at 192.168.0.46/24 and 192.168.0.52/24. Username and password are required for Telnet login.
When the two hosts log in to the device with different usernames and the same authentication method, they have different access permissions. One has permissions to manage the device, and the other has permissions to execute the read commands of all features.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9071 of the M9000-AI-E8 device.
Procedures
# Log in to the device through the console port, enter system view, and enable the Telnet server.
# Enable scheme authentication for VTY lines 0 to 63.
[Sysname] line vty 0 63
[Sysname-line-vty0-63] authentication-mode scheme
[Sysname-line-vty0-63] quit
# Create local user userA, assign user role network-admin to the user, configure a user password, and remove the default user role from the user.
[Sysname] local-user userA class manage
New local user added.
[Sysname-luser-manage-userA] authorization-attribute user-role network-admin
[Sysname-luser-manage-userA] service-type telnet
[Sysname-luser-manage-userA] password simple User1@1234
[Sysname-luser-manage-userA] undo authorization-attribute user-role network-operator
[Sysname-luser-manage-userA] quit
# Create user role roleB, and allow the user role to access the read commands of all features.
[Sysname] role name roleB
[Sysname-role-roleB] rule 1 permit read feature
[Sysname-role-roleB] quit
# Create local user userB, configure a user password, assign user role roleB to the user, and remove the default user role from the user.
[Sysname] local-user userB class manage
[Sysname-luser-manage-userB] authorization-attribute user-role roleB
[Sysname-luser-manage-userB] service-type telnet
[Sysname-luser-manage-userB] password simple User2@1234
[Sysname-luser-manage-userB] undo authorization-attribute user-role network-operator
[Sysname-luser-manage-userB] quit
# Create an ACL and configure rules to permit only traffic from 192.168.0.46 and 192.168.0.52.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule 1 permit source 192.168.0.46 0
[Sysname-acl-ipv4-basic-2000] rule 2 permit source 192.168.0.52 0
[Sysname-acl-ipv4-basic-2000] rule 3 deny source any
# Apply ACL 2000 to the Telnet server to control Telnet login based on source IP addresses.
[Sysname] telnet server acl 2000
1.        Use user account userA to Telnet to the device. Verify that you can manage and configure the device.
login: userA
Password:
* Copyright (c) 2004-2022 New H3C Technologies Co., Ltd. All rights reserved.*
<Sysname> ?
User view commands:
  archer              FPGA : archer
  archive             Archive configuration
  backup              Backup operation
  blade               Blade module
  boot-loader         Software image file management
  bootrom             Update/read/backup/restore bootrom
  bootrom-access      Bootrom access control
  cd                  Change current directory
  check               Integrity check
  clock               Specify the system clock
  copy                Copy a file
  debugging           Enable system debugging functions
  debugging-auto-off  Automatically turn off all debugging
  delete              Delete a file
  diagnostic          Generic OnLine Diagnostics (GOLD) module
  diagnostic-logfile  Diagnostic log file configuration
  dialer              Specify Dial-on-Demand Routing(DDR) configuration
                      information
  dir                 Display files and directories on the storage media
  display             Display current system information
  erase               Alias for 'delete'
  exception           Exception information configuration
  exit                Alias for 'quit'
---- More ----
2.        Use user account userB to Telnet to the device. Verify that you can execute only the read commands of all features.
login: userB
Password:
<Sysname> ?
User view commands:
  blade               Blade module
  copy                Copy a file
                      information
---- More ----
<Sysname>
3.        Verify that you cannot Telnet to the device from Host C.
Configuration files
acl basic 2000
 rule 3 deny
line vty 0 63
 password hash $h$6$3BcJwbpD4nbb4Pjd$fCTiXzLkjWHY0IsLI9E+1fV+WH4jEuu2Lf7Qa2Yog4/
1Z/ecgSXpecjuKxx4/hdRb92G+AZUTJK/AQJAmYVzKA==
 service-type telnet
 password hash $h$6$yvsoiG/zeU07hJ7u$31A5lXblIT86GEpK9wRfw2bJ38QHm+es6VEm4op/KYf
v1jGquN5te31wV0xQ1IZHL6Zv6/v6DcvMf2bp74gHNw==
 service-type telnet
role name roleB
