CLI example: Configuring an IKEv2-based IPsec NAT traversal tunnel between gateways
Device A is behind the NAT device. Hosts behind Device A use public IP address 3.3.3.1 to access the external network.
Configure IPsec tunnel interface-based IPsec on Device A and Device B to protect the traffic between subnet 10.1.1.0/24 and subnet 10.1.2.0/24.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R9071 of the M9000-AI-E8 device.
Procedures
Configuring Device A
1.        Assign IP addresses to interfaces:
# Assign an IP address to interface GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] ip address 1.1.1.1 255.255.0.0
2.        Configure settings for routing.
This example configures static routes, and the next hop in the routes is 1.1.1.2.
[DeviceA] ip route-static 2.2.2.2 16 1.1.1.2
3.        Add interfaces to security zones.
[DeviceA] security-zone name trust
[DeviceA-security-zone-Trust] import interface gigabitethernet 1/0/2
[DeviceA-security-zone-Trust] quit
[DeviceA] security-zone name untrust
[DeviceA-security-zone-Untrust] import interface gigabitethernet 1/0/1
[DeviceA-security-zone-Untrust] quit
4.        Configure a security policy:
Configure rules to permit traffic between the Untrust and Local security zones, so the devices can set up an IPsec tunnel:
# Configure a rule named ipseclocalout to allow Device A to send IPsec negotiation packets to Device B.
[DeviceA] security-policy ip
[DeviceA-security-policy-ip] rule name ipseclocalout
[DeviceA-security-policy-ip-1-ipseclocalout] source-zone local
[DeviceA-security-policy-ip-1-ipseclocalout] destination-zone untrust
[DeviceA-security-policy-ip-1-ipseclocalout] source-ip-host 1.1.1.1
[DeviceA-security-policy-ip-1-ipseclocalout] destination-ip-host 2.2.2.2
[DeviceA-security-policy-ip-1-ipseclocalout] action pass
[DeviceA-security-policy-ip-1-ipseclocalout] quit
# Configure a rule named ipseclocalin to allow Device A to receive the IPsec negotiation packets sent from Device B.
[DeviceA-security-policy-ip] rule name ipseclocalin
[DeviceA-security-policy-ip-2-ipseclocalin] source-zone untrust
[DeviceA-security-policy-ip-2-ipseclocalin] destination-zone local
[DeviceA-security-policy-ip-2-ipseclocalin] source-ip-host 2.2.2.2
[DeviceA-security-policy-ip-2-ipseclocalin] destination-ip-host 1.1.1.1
[DeviceA-security-policy-ip-2-ipseclocalin] action pass
[DeviceA-security-policy-ip-2-ipseclocalin] quit
Configure rules to permit the traffic between Host A and Host B:
# Configure a rule named trust-untrust to permit the packets from Host A to Host B.
[DeviceA-security-policy-ip] rule name trust-untrust
[DeviceA-security-policy-ip-3-trust-untrust] source-zone trust
[DeviceA-security-policy-ip-3-trust-untrust] destination-zone untrust
[DeviceA-security-policy-ip-3-trust-untrust] source-ip-subnet 10.1.1.0 24
[DeviceA-security-policy-ip-3-trust-untrust] destination-ip-subnet 10.1.2.0 24
[DeviceA-security-policy-ip-3-trust-untrust] action pass
[DeviceA-security-policy-ip-3-trust-untrust] quit
# Configure a rule named untrust-trust to permit the packets from Host B to Host A.
[DeviceA-security-policy-ip] rule name untrust-trust
[DeviceA-security-policy-ip-4-untrust-trust] source-zone untrust
[DeviceA-security-policy-ip-4-untrust-trust] destination-zone trust
[DeviceA-security-policy-ip-4-untrust-trust] source-ip-subnet 10.1.2.0 24
[DeviceA-security-policy-ip-4-untrust-trust] destination-ip-subnet 10.1.1.0 24
[DeviceA-security-policy-ip-4-untrust-trust] action pass
[DeviceA-security-policy-ip-4-untrust-trust] quit
[DeviceA-security-policy-ip] quit
5.        Configure an IPsec transform set to specify the packet encapsulation mode, security protocols, and algorithms.
The IPsec transform set settings at both sides of the IPsec tunnel must be the same.
[DeviceA] ipsec transform-set transform1
[DeviceA-ipsec-transform-set-transform1] protocol esp
[DeviceA-ipsec-transform-set-transform1] esp encryption-algorithm 3des-cbc
[DeviceA-ipsec-transform-set-transform1] esp authentication-algorithm md5
[DeviceA-ipsec-transform-set-transform1] quit
6.        Configure an IKEv2 keychain to specify the key information used for IKEv2 communication.
The preshared key used by both sides of the communication must be the same.
[DeviceA] ikev2 keychain keychain1
[DeviceA-ikev2-keychain-keychain1] peer peer1
[DeviceA-ikev2-keychain-keychain1-peer-peer1] address 2.2.2.2 16
[DeviceA-ikev2-keychain-keychain1-peer-peer1] identity address 2.2.2.2
[DeviceA-ikev2-keychain-keychain1-peer-peer1] pre-shared-key plaintext 123
[DeviceA-ikev2-keychain-keychain1-peer-peer1] quit
[DeviceA-ikev2-keychain-keychain1] quit
7.        Configure an IKEv2 profile to specify the security parameters used for setting up IKEv2 SAs.
[DeviceA] ikev2 profile profile1
[DeviceA-ikev2-profile-profile1] keychain keychain1
[DeviceA-ikev2-profile-profile1] identity local fqdn www.devicea.com
[DeviceA-ikev2-profile-profile1] match remote identity address 2.2.2.2 255.255.0.0
[DeviceA-ikev2-profile-profile1] authentication-method local pre-share
[DeviceA-ikev2-profile-profile1] authentication-method remote pre-share
[DeviceA-ikev2-profile-profile1] quit
8.        Configure an IPsec profile to establish an IPsec tunnel to protect the specified data:
[DeviceA] ipsec profile abc isakmp
[DeviceA-ipsec-profile-isakmp-abc] transform-set transform1
[DeviceA-ipsec-profile-isakmp-abc] ikev2-profile profile1
[DeviceA-ipsec-profile-isakmp-abc] quit
9.        Configure an IPsec tunnel interface, which encapsulates the traffic to be protected with IPsec:
# Create an IPsec tunnel interface, and apply the IPsec profile.
[DeviceA] interface tunnel 1 mode ipsec
[DeviceA-Tunnel1] ip address 4.4.4.1 255.255.255.0
[DeviceA-Tunnel1] source 1.1.1.1
[DeviceA-Tunnel1] destination 2.2.2.2
[DeviceA-Tunnel1] tunnel protection ipsec profile abc
[DeviceA-Tunnel1] quit
# Add the IPsec tunnel interface to security zone Untrust.
[DeviceA-security-zone-Untrust] import interface tunnel 1
# Configure a static route to direct the traffic to be protected to the IPsec tunnel interface.
[DeviceA] ip route-static 10.1.2.0 255.255.255.0 tunnel 1
Configuring Device B
[DeviceB-GigabitEthernet1/0/1] ip address 2.2.2.2 255.255.0.0
This example configures static routes, and the next hop in the routes is 2.2.2.1.
[DeviceB] ip route-static 3.3.3.1 16 2.2.2.1
[DeviceB] security-zone name trust
[DeviceB-security-zone-Trust] import interface gigabitethernet 1/0/2
[DeviceB-security-zone-Trust] quit
[DeviceB] security-zone name untrust
[DeviceB-security-zone-Untrust] import interface gigabitethernet 1/0/1
[DeviceB-security-zone-Untrust] quit
# Configure a rule named ipseclocalout to allow Device B to send IPsec negotiation packets to Device A.
[DeviceB] security-policy ip
[DeviceB-security-policy-ip] rule name ipseclocalout
[DeviceB-security-policy-ip-1-ipseclocalout] source-zone local
[DeviceB-security-policy-ip-1-ipseclocalout] destination-zone untrust
[DeviceB-security-policy-ip-1-ipseclocalout] source-ip-host 2.2.2.2
[DeviceB-security-policy-ip-1-ipseclocalout] destination-ip-host 1.1.1.1
[DeviceB-security-policy-ip-1-ipseclocalout] action pass
[DeviceB-security-policy-ip-1-ipseclocalout] quit
# Configure a rule named ipseclocalin to allow Device B to receive the IPsec negotiation packets sent from Device A.
[DeviceB-security-policy-ip] rule name ipseclocalin
[DeviceB-security-policy-ip-2-ipseclocalin] source-zone untrust
[DeviceB-security-policy-ip-2-ipseclocalin] destination-zone local
[DeviceB-security-policy-ip-2-ipseclocalin] source-ip-host 1.1.1.1
[DeviceB-security-policy-ip-2-ipseclocalin] destination-ip-host 2.2.2.2
[DeviceB-security-policy-ip-2-ipseclocalin] action pass
[DeviceB-security-policy-ip-2-ipseclocalin] quit
Configure rules to permit traffic between Host B and Host A:
# Configure a rule named trust-untrust to permit the packets from Host B to Host A.
[DeviceB-security-policy-ip] rule name trust-untrust
[DeviceB-security-policy-ip-3-trust-untrust] source-zone trust
[DeviceB-security-policy-ip-3-trust-untrust] destination-zone untrust
[DeviceB-security-policy-ip-3-trust-untrust] source-ip-subnet 10.1.2.0 24
[DeviceB-security-policy-ip-3-trust-untrust] destination-ip-subnet 10.1.1.0 24
[DeviceB-security-policy-ip-3-trust-untrust] action pass
[DeviceB-security-policy-ip-3-trust-untrust] quit
# Configure a rule named untrust-trust to permit the packets from Host A to Host B.
[DeviceB-security-policy-ip] rule name untrust-trust
[DeviceB-security-policy-ip-4-untrust-trust] source-zone untrust
[DeviceB-security-policy-ip-4-untrust-trust] destination-zone trust
[DeviceB-security-policy-ip-4-untrust-trust] source-ip-subnet 10.1.1.0 24
[DeviceB-security-policy-ip-4-untrust-trust] destination-ip-subnet 10.1.2.0 24
[DeviceB-security-policy-ip-4-untrust-trust] action pass
[DeviceB-security-policy-ip-4-untrust-trust] quit
[DeviceB-security-policy-ip] quit
[DeviceB] ipsec transform-set transform1
[DeviceB-ipsec-transform-set-transform1] protocol esp
[DeviceB-ipsec-transform-set-transform1] esp encryption-algorithm 3des-cbc
[DeviceB-ipsec-transform-set-transform1] esp authentication-algorithm md5
[DeviceB-ipsec-transform-set-transform1] quit
[DeviceB]ikev2 keychain keychain1
[DeviceB-ikev2-keychain-keychain1] peer peer1
[DeviceB-ikev2-keychain-keychain1-peer-peer1] address 3.3.3.1 16
[DeviceB-ikev2-keychain-keychain1-peer-peer1] identity address 3.3.3.1
[DeviceB-ikev2-keychain-keychain1-peer-peer1] pre-shared-key plaintext 123
[DeviceB-ikev2-keychain-keychain1-peer-peer1] quit
[DeviceB-ikev2-keychain-keychain1] quit
[DeviceB] ikev2 profile profile1
[DeviceB-ikev2-profile-profile1] keychain keychain1
[DeviceB-ikev2-profile-profile1] match remote identity fqdn www.devicea.com
[DeviceB-ikev2-profile-profile1] authentication-method local pre-share
[DeviceB-ikev2-profile-profile1] authentication-method remote pre-share
[DeviceB-ikev2-profile-profile1] quit
[DeviceB] ipsec profile abc isakmp
[DeviceB-ipsec-profile-isakmp-abc] transform-set transform1
[DeviceB-ipsec-profile-isakmp-abc] ikev2-profile profile1
[DeviceB-ipsec-profile-isakmp-abc] quit
[DeviceB] interface tunnel 1 mode ipsec
[DeviceB-Tunnel1] ip address 4.4.4.2 255.255.255.0
[DeviceB-Tunnel1] source 2.2.2.2
[DeviceB-Tunnel1] destination 3.3.3.1
[DeviceB-Tunnel1] tunnel protection ipsec profile abc
[DeviceB-Tunnel1] quit
[DeviceB-security-zone-Untrust] import interface tunnel 1
[DeviceB] ip route-static 10.1.1.0 255.255.255.0 tunnel 1
After the configuration is completed, Device A will automatically initiate IKE negotiation with Device B. After IKE negotiation succeeds, the tunnel interface will come up and traffic between two subnets will be IPsec-protected. This example uses Device A to verify the configuration.
# Display brief IP configuration for interfaces on Device A.
[DeviceA] display ip interface brief
*down: administratively down
(s): spoofing  (l): loopback
Interface           Physical Protocol IP address/Mask    VPN instance Description
GE1/0/1             up       up       1.1.1.1/16         --           --
GE1/0/2             up       up       10.1.1.1/24        --           --
Tun1                up       up       4.4.4.1/24         --           --
# Display tunnel interface information on Device A.
[DeviceA] display interface Tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64 kbps
Maximum transmission unit: 1444
Internet address: 4.4.4.1/24 (primary)
Tunnel TTL 255
Tunnel protocol/transport IPsec/IP
# Display IPsec SAs on Device A.
[DeviceA] display ipsec sa
Interface: Tunnel1
  IPsec profile: abc
  Mode: ISAKMP
    Tunnel id: 0
    Encapsulation mode: tunnel
    Perfect Forward Secrecy:
    Transmitting entity: Initiator
    Path MTU: 1388
    Tunnel:
        local  address/port: 1.1.1.1/500
        remote address/port: 2.2.2.2/500
    Flow:
        sour addr: 0.0.0.0/0.0.0.0  port: 0  protocol: ip
        dest addr: 0.0.0.0/0.0.0.0  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 2701952073 (0xa10c8449)
      Connection ID: 4294967296
      Transform set: ESP-ENCRYPT-SM1-CBC-128 ESP-AUTH-SM3
      SA duration (kilobytes/sec): 1843200/3600
      SA remaining duration (kilobytes/sec): 1843200/3180
      Max received sequence-number: 0
      Anti-replay check enable: Y
      Anti-replay window size: 64
      UDP encapsulation used for NAT traversal: N
      Status: Active
    [Outbound ESP SAs]
      SPI: 3607077598 (0xd6ffa2de)
      Connection ID: 12884901889
      Max sent sequence-number: 0
      Status: Active
# Verify that a private IP address in subnet 10.1.1.0/24 can ping a private IP address in subnet 10.1.2.0/24 successfully.
[DeviceA] ping -a 10.1.1.2 10.1.2.2
Ping 10.1.2.1 (10.1.2.1) from 10.1.1.1: 56 data bytes, press CTRL_C to break
56 bytes from 10.1.2.1: icmp_seq=0 ttl=255 time=1.000 ms
56 bytes from 10.1.2.1: icmp_seq=1 ttl=255 time=1.000 ms
56 bytes from 10.1.2.1: icmp_seq=2 ttl=255 time=0.000 ms
56 bytes from 10.1.2.1: icmp_seq=3 ttl=255 time=1.000 ms
56 bytes from 10.1.2.1: icmp_seq=4 ttl=255 time=0.000 ms
--- Ping statistics for 10.1.2.1 ---
round-trip min/avg/max/std-dev = 0.000/0.600/1.000/0.490 ms
Configuration files
interface Tunnel1 mode ipsec
 source 1.1.1.1
 destination 2.2.2.2
security-zone name Trust
 import interface GigabitEthernet1/0/2
security-zone name Untrust
 import interface GigabitEthernet1/0/1
 import interface Tunnel1
 ip route-static 2.2.0.0 16 1.1.1.2
 ip route-static 10.1.2.0 24 Tunnel1
 encapsulation-mode tunnel
 protocol esp
 peer peer1
 keychain keychain1
security-policy ip
 rule 0 name ipseclocalout
  action pass
  source-zone local
 rule 1 name ipseclocalin
  action pass
  source-zone untrust
 rule 2 name trust-untrust
  action pass
  source-zone trust
  source-ip-subnet 10.1.1.0 255.255.255.0
  destination-ip-subnet 10.1.2.0 255.255.255.0
 rule 3 name untrust-trust
  action pass
  source-zone untrust
  source-ip-subnet 10.1.2.0 255.255.255.0
  destination-ip-subnet 10.1.1.0 255.255.255.0
 ip address 10.1.2.1 255.255.255.0
 source 2.2.2.2
 destination 3.3.3.1
 ip route-static 3.3.0.0 16 2.2.2.1
 ip route-static 10.1.1.0 24 Tunnel1
 protocol esp
 peer peer1
  address 3.3.3.1 255.255.0.0
 keychain keychain1
security-policy ip
  action pass
  source-zone local
  destination-ip-host 3.3.3.1
  action pass
  source-zone untrust
  source-ip-host 3.3.3.1
  action pass
  source-zone trust
  action pass
  source-zone untrust
