CLI example: Using vSystems for enterprise network isolation (non-default vSystems have public network interfaces)
As shown in Figure 1:
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on E8371 of the F5000-AI160 device.
Procedures
Configuring vSystem vsys1
1.        Create vSystem vsys1 and assign interfaces to the vSystem:
# Create vSystem vsys1 and configure a description for the vSystem.
[Device] vsys vsys1
[Device-vsys-2-vsys1] description vsys-1
# Assign interfaces GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to vSystem vsys1.
[Device-vsys-2-vsys1] allocate interface gigabitethernet 1/0/1
Some configurations on the interface are removed.
[Device-vsys-2-vsys1] allocate interface gigabitethernet 1/0/2
[Device-vsys-2-vsys1] quit
2.        Log in to vSystem vsys1, assign IP addresses to interfaces, and add interfaces to security zones:
# Log in to vSystem vsys1.
[Device] switchto vsys vsys1
<Device-vsys1> system-view
# Assign IP addresses to interfaces.
[Device-vsys1] interface gigabitethernet 1/0/1
[Device-vsys1-GigabitEthernet1/0/1] ip address 1.1.1.1 24
[Device-vsys1-GigabitEthernet1/0/1] quit
[Device-vsys1] interface gigabitethernet 1/0/2
[Device-vsys1-GigabitEthernet1/0/2] ip address 192.168.1.1 24
[Device-vsys1-GigabitEthernet1/0/2] quit
# Add interfaces to security zones.
[Device-vsys1] security-zone name trust
[Device-vsys1-security-zone-Trust] import interface gigabitethernet 1/0/2
[Device-vsys1-security-zone-Trust] quit
[Device-vsys1] security-zone name untrust
[Device-vsys1-security-zone-Untrust] import interface gigabitethernet 1/0/1
[Device-vsys1-security-zone-Untrust] quit
3.        Configure settings for routing. This example configures a static route. In the route, the next hop IP address is 1.1.1.2 for users in vSystem vsys1 to access the Internet.
[Device-vsys1] ip route-static 0.0.0.0 0 1.1.1.2
4.        Configure a rule named trust-untrust in the IPv4 security policy to allow users in subnet 192.168.1.128/25 to access the Internet.
[Device-vsys1] security-policy ip
[Device-vsys1-security-policy-ip] rule name trust-untrust
[Device-vsys1-security-policy-ip-1-trust-untrust] source-zone trust
[Device-vsys1-security-policy-ip-1-trust-untrust] destination-zone untrust
[Device-vsys1-security-policy-ip-1-trust-untrust] source-ip-subnet 192.168.1.128 25
[Device-vsys1-security-policy-ip-1-trust-untrust] action pass
[Device-vsys1-security-policy-ip-1-trust-untrust] quit
[Device-vsys1-security-policy-ip] quit
5.        Configure NAT:
# Configure ACL 2000, and create a rule to permit the packets only from 192.168.1.128/25 to be translated.
[Device-vsys1] acl basic 2000
[Device-vsys1-acl-ipv4-basic-2000] rule permit source 192.168.1.128 0.0.0.127
[Device-vsys1-acl-ipv4-basic-2000] quit
# Enable outbound dynamic NAT with Easy IP on interface GigabitEthernet 1/0/1 so that NAT translates the source addresses of the packets matching the ACL and destined for the Internet into the IP address of interface GigabitEthernet 1/0/1.
[Device-vsys1-GigabitEthernet1/0/1] nat outbound 2000
6.        Return to the default vSystem from vSystem vsys1.
[Device-vsys1-GigabitEthernet1/0/1] return
<Device-vsys1> quit
[Device]
Configuring vSystem vsys2
1.        Create vSystem vsys2 and assign interfaces to the vSystem:
# Create vSystem vsys2 and configure a description for the vSystem.
[Device] vsys vsys2
[Device-vsys-3-vsys2] description vsys-2
# Assign interfaces GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 to vSystem vsys2.
[Device-vsys-3-vsys2] allocate interface gigabitethernet 1/0/3
[Device-vsys-3-vsys2] allocate interface gigabitethernet 1/0/4
[Device-vsys-3-vsys2] quit
2.        Log in to vSystem vsys2,  assign IP addresses to interfaces, and add interfaces to security zones:
# Log in to vSystem vsys2.
[Device] switchto vsys vsys2
<Device-vsys2> system-view
[Device-vsys2] interface gigabitethernet 1/0/3
[Device-vsys2-GigabitEthernet1/0/3] ip address 1.1.2.1 24
[Device-vsys2-GigabitEthernet1/0/3] quit
[Device-vsys2] interface gigabitethernet 1/0/4
[Device-vsys2-GigabitEthernet1/0/4] ip address 192.168.2.1 24
[Device-vsys2-GigabitEthernet1/0/4] quit
[Device-vsys2] security-zone name trust
[Device-vsys2-security-zone-Trust] import interface gigabitethernet 1/0/4
[Device-vsys2-security-zone-Trust] quit
[Device-vsys2] security-zone name untrust
[Device-vsys2-security-zone-Untrust] import interface gigabitethernet 1/0/3
[Device-vsys2-security-zone-Untrust] quit
3.        Configure settings for routing. This example configures a static route. In the route, the next hop IP address is 1.1.2.2 for users in vSystem vsys2 to access the Internet.
[Device-vsys2] ip route-static 0.0.0.0 0 1.1.2.2
4.        Configure a rule named trust-untrust in the IPv4 security policy to allow users in subnet 192.168.2.0/24 to access the Internet.
[Device-vsys2] security-policy ip
[Device-vsys2-security-policy-ip] rule name trust-untrust
[Device-vsys2-security-policy-ip-1-trust-untrust] source-zone trust
[Device-vsys2-security-policy-ip-1-trust-untrust] destination-zone untrust
[Device-vsys2-security-policy-ip-1-trust-untrust] source-ip-subnet 192.168.2.0 24
[Device-vsys2-security-policy-ip-1-trust-untrust] action pass
[Device-vsys2-security-policy-ip-1-trust-untrust] quit
[Device-vsys2-security-policy-ip] quit
5.        Configure NAT:
# Configure ACL 2000, and create a rule to permit the packets only from 192.168.2.0/24 to be translated.
[Device-vsys2] acl basic 2000
[Device-vsys2-acl-ipv4-basic-2000] rule permit source 192.168.2.0 0.0.0.255
[Device-vsys2-acl-ipv4-basic-2000] quit
# Enable outbound dynamic NAT with Easy IP on interface GigabitEthernet 1/0/3 so that NAT translates the source addresses of the packets matching the ACL and destined for the Internet into the IP address of interface GigabitEthernet 1/0/3.
[Device-vsys2-GigabitEthernet1/0/3] nat outbound 2000
6.        Return to the default vSystem from vSystem vsys2.
[Device-vsys2-GigabitEthernet1/0/3] return
<Device-vsys2> quit
[Device]
# Verify that the vSystems are running correctly on the device. The device has three active vSystems.
[Device] display vsys
ID       Name          Status            Description
1        Admin         Active            Default
2        vsys1         Active            vsys-1
3        vsys2         Active            vsys-2
# Verify that users in subnet 192.168.1.128/25 can access the Internet.
C:\> ping 3.3.3.3
Pinging 3.3.3.3 with 32 bytes of data:
Reply from 3.3.3.3: bytes=32 time=51ms TTL=255
Reply from 3.3.3.3: bytes=32 time=44ms TTL=255
Reply from 3.3.3.3: bytes=32 time=1ms TTL=255
Ping statistics for 3.3.3.3:
    Minimum = 1ms, Maximum = 51ms, Average = 24ms
# Verify that users in subnet 192.168.2.0/24 can access the Internet.
C:\> ping 3.3.3.3
Reply from 3.3.3.3: bytes=32 time=25ms TTL=255
Reply from 3.3.3.3: bytes=32 time=36ms TTL=255
    Minimum = 1ms, Maximum = 36ms, Average = 16ms
Configuration files
vsys vsys1 id 2
 description vsys1
 allocate interface GigabitEthernet1/0/1.1
vsys vsys2 id 3
 description vsys2
 allocate interface GigabitEthernet1/0/1.2
 vlan-type dot1q vid 10
 vlan-type dot1q vid 20
 ip route-static vpn-instance vsys1 10.20.0.0 24 vpn-instance vsys2
 ip route-static vpn-instance vsys2 10.10.0.0 24 vpn-instance vsys1
switchto vsys vsys1
security-zone name Trust
 import interface GigabitEthernet1/0/1.1
security-zone name Untrust
 import interface vSys-interface2
security-policy ip
 rule 0 name vpc1
  action pass
  source-zone trust
 rule 1 name vpc2
  action pass
  source-zone untrust
  destination-zone trust
switchto vsys vsys2
 import interface GigabitEthernet1/0/1.2
 import interface vSys-interface3
security-policy ip
 rule 0 name vpc1
  action pass
  source-zone trust
 rule 1 name vpc2
