Delete VM backup files
Perform this task to delete backup files in bulk or one by one for a VM. If you select the forcible deletion option, the system also clears related information in the database when deleting backup files. If the backup files to delete are saved on a remote server that is disconnected temporarily, the system only deletes the related database information. However, those backup files cannot be used for VM restoration even if the remote server is connected again.
  1. On the top navigation bar, click Resources.
  1. From the left navigation pane, select Compute > host pool name > host name > VM name or Compute > host pool name > cluster name > host name > VM name.
  1. Click the Backup Management tab.
  1. Select backup files from the backup file list, and then click Delete. Alternatively, click More in the Actions column for a backup file and select Delete.
  1. Select the forcible deletion option as needed, and then click OK.
