Perform this task to download a backup file of a VM to a local folder. You can use the locally saved backup file to restore the VM if the original file has been deleted on CAS.
On the top navigation bar, click Resources.
From the left navigation pane, select Compute > host pool name > host name > VM name or Compute > host pool name > cluster name > host name > VM name.
Click the Backup Management tab.
Click Download in the Actions column for a backup file.
