Migrate an external VM to CAS
Perform this task to create a migration task to migrate a VM and configure scheduled migration settings for the VM. The migration does not require any agents and features short service interruption time.
Create a migration task
  1. On the top navigation bar, click Resources, and then select External Platform.
  1. Click the Migration Tasks tab.
  1. Click Create Migration Task.
  1. Configure the parameters as described in "Parameters."
  1. Click OK.
Edit a migration task
  1. Click Edit in the Actions column for the target migration task.
  1. Edit the parameters as needed, and then click OK.
Complete a migration task
  1. Click Complete in the Actions column for the target migration task.
  1. In the dialog box that opens, click OK.
Delete a migration task
  1. Click Delete in the Actions column for the target migration task.
Configure queue settings
There is a limitation on the number of concurrently executed tasks in integrating external clouds. To handle more tasks within the same timeframe, you can control the number of tasks by setting the maximum number of concurrent tasks in the queue for external cloud migration. This allows tasks to be divided into multiple batches and executed one by one to reduce resource competition.
  1. Click Queue Settings.
  1. Configure the queue settings, as described in "Parameters."
  1. Click OK.
Operate multiple migration tasks in bulk
  1. Select the target migration tasks, and then click Bulk Edit, Bulk Complete, or Bulk Delete.
  1. Configure the parameters as needed and then click OK, or click OK in the dialog box that opens.
View migration state information
  1. Click the name of the target source VM.
On the page that opens, you can view the migration progress, device information, and log and edit, complete, or delete the migration task.
Calculate the capacity of data to be migrated on a VM
  1. Click Calculate Capacity to Migrate.
The capacity to migrate is displayed in the Device Info area.
Select an external platform
Select External Platform: Select the external platform to which the VM to be migrated belongs.
Select a VM
Select VM: Select the VM to be migrated.
Basic settings
Select host
Select Host: Select the target host to which the VMware VM will be migrated.
Hardware information
