On the top navigation bar, click Resources.
From the left navigation pane, select AZs > Compute AZs.
On the AZs tab, click Create.
Configure AZ parameters as required.
Table-1 Configuring compute AZ parameters
Parameter |
AZ Alias |
Compute AZ name. |
Hypervisor |
Hypervisor used for node virtualization. Available options:
Creation Mode |
AZ |
To use an existing Nova AZ, select its name. To create a new Nova AZ, assign it a name. You will be unable to change that name after you create the Nova AZ. |
Available Hosts |
Compute nodes available for a Nova AZ. If you select New AZ, select one or multiple available compute nodes to create the AZ. The displayed host names are names assigned to the compute nodes when they were created. |
