Plan availability zones (AZs)
Availability zones (AZs) are logical groups of resources available for a service. A system administrator can manage the resources available for organizations by assigning them to different AZs. The system supports the following types of AZs:
Developed based on OpenStack Nova, the compute AZs in the system are also called Nova AZs. If you use a Nova AZ for different compute services, you can assign different compute AZ alias to that Nova AZ to identify those compute services.
Developed based on OpenStack Cinder, the storage AZs in the system are also called Cinder AZs.
In the system, each compute node provides a Cinder AZ. When you create a compute node, you must assign it a Cinder AZ name. You can then use a Cinder AZ to provide one or multiple storage services.
Make sure two hosts are available for cloud host migration.
Plan AZs
Follow these rules when planning AZs:
·          When the system is interconnected with a CAS CVM, a compute resource pool in the system is a CAS host pool or a cluster in a host pool.
·          When the system is interconnected with a VMware virtualization platform, a compute resource pool in the system is a VMware cluster.
Example
Assume that Company A has the following compute resources:
Table-1 shows the AZ plan of the company.
Table-1 AZ planning example
Dept.
Org1
Org2
Org3
Org4
Hypervisor
CAS
VMware
Hosts
16 CVK hosts
16 CVK hosts
16 ESXi hosts
Compute resource pool
HPool1
HPool2
Cluster1
Storage AZ
Cinder1
Cinder2
Cinder3
Compute AZ
Nova1
Nova2
Nova3
Storage AZ alias
Org1 AZ
Org2 AZ
Org3 AZ
Org4 AZ
Compute AZ alias
Org1 AZ
Org2 AZ
Org3 AZ
Org4 AZ
