Configure the encryption module according to the manufacturer's instructions and ensure the network connectivity between the encryption module and the system.
Obtain the IP address, port information, username, and password for the FMPLAT to interoperate with CloudOS.
On the top navigation bar, click System.
From the left navigation pane, select System Settings > Security Settings > Encryption Module Settings.
Configure the parameters as required.
Click Save Configuration.
Edit the configuration if the system prompts configuration saving failure.
Table-1 Configuring encryption module parameters
Parameter |
Encryption Module IP |
Enter the IP address obtained from the manufacturer of the encryption module. |
Encryption Module Port |
Enter the port number obtained from the manufacturer of the encryption module. |
Encryption Key |
Enter the encryption key. |
Encryption Module Manufacturer |
Select FMPLAT as the manufacturer. |
Key Password |
Set the key password. |
Username |
Enter the obtained username. |
Password |
Enter the obtained password. |
Click Edit to edit the parameters as needed.
Click Save.
Click Start Encryption.
