On the top navigation bar, click Cloud Services, and then select Load Balancing from the Network menu.
Click a load balancer name.
Click the Real Server Groups tab.
Click the name of a real server to view its details.
To edit the weight of a real server, click the
icon in the Weight column for that real server, edit the weight, and then click OK.
To change the enabling state of a real server, click the toggle button in the State column for that real server.
To change the enabling state of multiple real servers in bulk, select the real servers, and then click Enable or Off on top of the list.
If you delete a real server, the load balancer might be unable to provide services to users, and all services associated with the real server will be interrupted. Before performing this operation, make sure you understand the potential impact on the services.
Click Delete in the Actions column for a real server. To delete multiple real servers in bulk, select the target real servers, and then click Delete.
