Configure the encryption module according to the manufacturer's instructions and ensure the network connectivity between the encryption module and the system.
Obtain the IP address and port information of the encryption module.
On the top navigation bar, click System.
From the left navigation pane, select System Settings > Security Settings > Encryption Module Settings.
Configure the parameters as required.
Click Save Configuration.
Edit the configuration if the system prompts configuration saving failure.
Table-1 Configuring encryption module parameters
Parameter |
Encryption Module IP |
Enter the IP address obtained from the manufacturer of the encryption module. |
Encryption Module Port |
Enter the port number obtained from the manufacturer of the encryption module. |
Encryption Module Manufacturer |
Select FM as the manufacturer. |
Encryption Key |
Enter the encryption key. |
Click Edit to edit the parameters as needed.
Click Save.
Click Start Encryption.
