YAML application deployment example (without initial container configuration)
This example does not provide configuration of an initial container.
apiVersion: apps/v1    # Required. Specify the API version, which is fixed at apps/v1.
kind: Deployment     # Required. Specify an application type, which can be Deployment (stateless application) or StatefulSet (stateful application).
metadata:
  labels:    # Required. Specify an application label in the format of app: application name.
    app: tomcattest
  name: tomcattest    # Required. Specify an application name, which must be the same as that on the basic settings page and must be unique in the same application group.
  namespace: spaceh0h8w1lp    # Namespace selected for the application group on the basic settings page.
namespace
spec:
  replicas: 1
  selector:    # Required. Specify a label selector, which must be the same as the label of the template (app: application name).
    matchLabels:
      app: tomcattest
  template:
    metadata:
      labels:
        app: tomcattest     # Required. Enter a label in the format of app: application name.
    spec:
      affinity:     # A container scheduling policy.
        nodeAffinity:     # Define the nodes that can schedule a pod.
          preferredDuringSchedulingIgnoredDuringExecution:
          - preference:
              matchExpressions:
              - key: beta.kubernetes.io/instance-type
                operator: In
                values:
                - adcf1f03-9fda-4cc8-8d29-66f384ed6581
            weight: 50
        podAffinity:     # Define which pods with workloads are deployed in the same topology domain.
          - podAffinityTerm:
              labelSelector:
                matchExpressions:
                - key: apps
                  operator: In
                  values:
                  - testbb
              namespaces:
              - space2woixyjc
              topologyKey: kubernetes.io/hostname
            weight: 100
        podAntiAffinity:    # Define which pods with workloads are not deployed in the same topology domain.
          - podAffinityTerm:
              labelSelector:
                matchExpressions:
                - key: apps
                  operator: NotIn
                  values:
                  - testccc
            weight: 100
      containers:
      - args:    # Command parameter.
        - --port=8080
        command:    # Command to be executed.
        - /bin/start
        env:    # Environment variable used to change container configuration after deployment.
        - name: SERVICE_NAME
          value: tomcattest
        image: os-harbor-svc.default.svc.cloudos:443/user/1df71957d770436493a84f24d9344853/tomcat:8.0   # Required. Address of the image used by the container.
        imagePullPolicy: IfNotPresent    # Image check and update policy upon startup: Always, Never, or IfNotPresent.
        livenessProbe:    # Liveness check.
          exec:
            command:
            - /bin/bash
            - -c
            - /tmp/healthy
          failureThreshold: 12
          initialDelaySeconds: 12
          periodSeconds: 12
          successThreshold: 1
          timeoutSeconds: 10
        name: tomcattest    # Required. Container name.
        readinessProbe:    # Readiness check.
          failureThreshold: 1
          httpGet:
            path: /health
            port: 8080
            scheme: HTTP
          initialDelaySeconds: 10
          periodSeconds: 3
          successThreshold: 2
          timeoutSeconds: 3
        resources:    # Required. Container flavor.
          limits:    # Required. Maximum resources allowed for the operation of the container.
            cpu: 300m    # CPU resource.
            memory: 300Mi    # Memory resource.
          requests:    # Minimum resources guaranteed for the startup of the container. The request must be smaller than the limit.
            cpu: 200m
            memory: 200Mi
        securityContext:
          capabilities:    # Linux capabilities.
            add:
            - DAC_OVERRIDE
            - FOWNER
            - FSETID
          privileged: false    # Run the container in privileged mode. In this mode, the processes in the container run as root.
          readOnlyRootFilesystem: true     # Read-only access to the root file system
  runAsUser: 0     # User UID. The container runs with the privilege of the user.
        terminationMessagePath: /dev/termination-log
        terminationMessagePolicy: File
        volumeMounts:
        - mountPath: /tmp    # Mount path.
- mountPath: /tmppvc
        - mountPath: /conf
        - mountPath: /seca
      dnsPolicy: ClusterFirst
      hostIPC: true    # Use the IPC namespace of the host.
      hostNetwork: true    # Use the network namespace of the host.
     hostPID: true    # Use the PID namespace of the host.
      restartPolicy: Always
      schedulerName: default-scheduler
      securityContext: {}
      serviceAccount: default
      serviceAccountName: default
      terminationGracePeriodSeconds: 30
      volumes:    # The configMap, secret, persistentVolumeClaim, and hostPath volume types are supported.
      - hostPath:
          path: /etc/hosts
          type: ""
      - name: pvc-htb3am891
        persistentVolumeClaim:
          claimName: pvctesta
      - name: secret-653i9fy20
        secret:
          defaultMode: 420
          secretName: default-token-hb627
      - configMap:
          defaultMode: 420
