On the top navigation bar, click Business Apps.
From the left navigation pane, select Microservices > Microservices Engines.
Click Create.
Configure the parameters as needed, and then click Create.
Parameter |
Engine Name |
Specify an alias for the microservices engine. You can select a microservices engine by its alias when you create an application group. The alias is a string of 1 to 30 characters and can contain letters, digits, underscores (_), and hyphens (-). |
Resource Configuration |
Select a container cluster to provide an isolated working environment for the microservices engine. The system will automatically deploy the engine component container to the selected container cluster. The following cluster types are available:
Only services deployed in the selected container AZ or cluster can use the microservices engine. |
Access IP |
Specify the access IP address of the microservices engine. If you do not configure this parameter, the VIP will be used. |
Specify a description for the engine. |
Parameter |
Engine Type |
Select Dubbo. |
Component Type |
Select a component type:
Zookeeper engine component configuration |
Version |
Only the 2.7.3 version is supported. |
Engine Component |
The registration center is required, and the configuration center is optional. |
Register Center Type |
Only dubbo-zookeeper3.5.6 is supported. |
Configuration Center Type |
Only Nacos2.0.1 is supported. |
Nacos engine component configuration |
Nacos provides registration center and configuration center capabilities, and you do not need to configure them. |
Instance Quantity |
Specify the number of instances as needed. |
Container Flavor |
Specify the container startup and operation limits. The startup limit cannot be higher than the operation limit.
Cluster External Port |
Manually specify or configure the system to automatically allocate the internal/external network port number for the engine component. |
MySQL Configuration |
Configure MySQL settings for the configuration center.
The microservices engine will create a registration center and a configuration center automatically. You can click the engine name and access the detailed engine information page to view the registration center and configuration center addresses, domain names, and ports.
