Create a traditional application package
About a traditional application package
A traditional application package includes the following parts:
Example application parameter file
  "name": "apache-tomcat",                     # Application name
  "type": "software",                           # Application type
  "app_file": "apache-tomcat-9.0.0.M21.tar.gz",     # Application package name
  "endpoint": {                               # API port. The value can be a fixed value or a built-in function. Currently, the “$get_var_from_config()” function is supported, which obtains variables automatically from the customized_config parameter.
    "port": 8080,
    "protocol": "TCP"
  "customized_config": {                        # Customized parameter settings. The parameters can be edited during application deployment and finally deployed to the host as environment variables.
    "tomcat_port": {
      "type": "string",
      "default": "8080",
      "description": "tomcat port"
    "install_dir":{
      "type": "string",
      "default": "/data/tomcat",
      "description": "The directory where tomcat will be installed in"
