Perform this task to view the state, local resource, peer resource, resource type, organization, local subnets, and peer subnets for a peering connection.
On the top navigation bar, click Cloud Services, and then select Peering Connections from the Network menu.
From the left navigation pane, select Peering Connections.
Click the name of a peering connection.
Click the Local Subnets or Peer Subnets tab to view subnet information.
Click Edit in the Actions column for a peering connection.
Edit the description, and click OK.
Pending peering connections can be deleted only by the creator.
Deleting a peering connection will disconnect two VPCs or classic networks from each other. Make sure you are fully aware of the impact. As a best practice, verify that the services provided by the two ends of a peering connection can be interrupted before you delete the peering connection. |
Click Delete in the Actions column for a peering connection, or select multiple peering connections and click Delete.
In the dialog box that opens, click OK.
