Perform this task to publish a VMware VM template as an image.
On the top navigation bar, click Resources.
From the left navigation pane, select Virtualization.
From the Virtualization menu pane, select a VMware compute resource pool, a cluster, and then a host.
Click the Templates tab.
Click Publish Image in the Actions column for a template.
Configure parameters.
