From the left navigation pane, select Service Subscription > Credential Management.
Select a service gateway from the service gateway filter list.
Click Create. Specify a name and description for the credential.
To enable the IP denylist and allowlist feature, select On for IP Allowlist and Denylist Settings. Alternatively, you can access the credential details page, click Set to the right of the IP Allowlist and Denylist field.
To add entries to the allowlist, select the Allowlist option, and then enter the IP address and description for the entry to be added to the allowlist. To add more entries, click the plus sign +.
To add entries to the denylist, select the Denylist option, and then enter the IP address and description for the entry to be added to the denylist. To add more entries, click the plus sign +.
To add multiple entries in bulk, click Bulk Edit.
To view and copy the automatically generated AK or SK, click the name of the created credential.
