From the left navigation pane, select Application Integration > Backend Services.
Click the name of a backend service.
Click New API to add an API to the backend service.
Parameter |
Basic Info |
Request Info |
Configure request information such as parameter name, location, and type. |
Response Info |
To add response information, click Add, and then enter a code, description, and sample response. |
To import APIs from a swagger file, click Import from Swagger. The following methods are available:
Import Files—Import files compliant with the OpenAPI 3 and Swagger 2 standards.
