Reset fee
Perform this task to clear the history fee records for cloud hosts and triggers a new charging policy. The system supports resetting the fee for a single cloud host and for multiple cloud hosts in bulk. When resetting the fee for a single cloud host, you can set a reset time to clear all fee records before the specified time point. Charging starts from the specified reset time. The bulk reset operation does not support configuring the reset time. Charging starts from the current startup time.
·          Only the system administrator can reset the fee.
·          You can reset the fee for only the cloud hosts with fees
·          When reset the fee for a single cloud host, the configured reset time cannot be earlier than the earliest fee record.
To reset the fee:
  1. On the top navigation bar, click Cloud Services, and then select Cloud Hosts from the Compute menu.
  1. Perform either of the following tasks:
  1. Click OK.
