Configure an INFOSEC encryption module
Configuration flow
Figure-1 Configuration flow
Table-1 Configuration flow
Install cloud service installation package and components
Upload and deploy corresponding cloud service installation package and components in advance. For more information, see "Configure cloud services and system components."
Create public key certificate
Create a public key certificate provided by the manufacturer in the system in advance.
Configure the encryption module
Configure INFOSEC encryption module.
Obtain the public key certificate file provided by the third-party manufacturer of the encryption module in advance.
  1. On the top navigation bar, click System.
  1. From the left navigation pane, select System Settings > Security Settings > Public Key Certificate.
  1. Click Create Public Key Certificate. Configure public key certificate parameters.
Table-2 Configuring public key certificate parameters
Parameter
Certificate Name
Specify the name of the customized certificate.
Public Key Subject
Specify the subject of the public key certificate.
Enter the public key certificate.
  1. Click OK.
  1. From the left navigation pane, select System Settings > Security Settings > Encryption Module Settings.
  1. Click Create Encryption Module Settings. Configure parameters for the encryption module.
  1. Click Test Connectivity to test the connectivity of the encryption module.
Table-3 Configuring encryption module parameters
Parameter
Platform Name
Specify the name of the encryption platform.
appId
Enter the App ID obtained from the manufacturer.
SecretKey
Enter the secret key obtained from the manufacturer.
IP/Port
Enter the obtained encryption module IP or port.
Protocol
HTTP protocol is supported.
Management and maintenance
Edit public key certificate
  1. Select the target public key certificate. Click Edit. Configure public key certificate parameters.
  1. Click OK.
Enable public key certificate
  1. Select the target public key certificate. Click Enable.
  1. Click OK.
Delete public key certificate
Deleting public key certificates will make corresponding users unable to log in normally. Perform this operation with caution.
  1. Select the target public key certificate. Click Delete.
  1. Click OK.
