Configure a WST encryption module
Configure encryption module
  1. On the top navigation bar, click System.
  1. From the left navigation pane, select System Settings > Security Settings > Encryption Module Settings.
  1. Configure parameters for the encryption module. Click Save Configuration or Edit.
Table-1 Configuring encryption module parameters
Parameter
Encryption Module IP/Port
Enter the obtained encryption module IP or port.
Encryption Key
Set the encryption key for encryption as required by the manufacturer.
Encryption Module Manufacturer
Specify the encryption module manufacturer as WST.
Key Password
Set the key password.
TIPThis filed is optional. If you do not set a key password, the system uses the default key password 11111111.
Start encryption
  1. Click Start Encryption.
