Configure a DA encryption module
Configure an encryption module
  1. On the top navigation bar, click System.
  1. From the left navigation pane, select System Settings > Security Settings > Encryption Module Settings.
  1. Configure parameters for the encryption module. Click Save Configuration or Edit.
Table-1 Configuring encryption module parameters
Parameter
Encryption Module IP/Port
Enter the obtained encryption module IP or port.
Encryption Key
Set the encryption key for encryption as required by the manufacturer.
Encryption Module Manufacturer
Specify the encryption module manufacturer as DA.
Start encryption
  1. Click Start Encryption.
