Create a cloud disk and attach it to a cloud host
Attaching a ONEStor-ISCSI cloud disk to a cloud host requires using specific CAS versions. For more information, see Key Features and Software Platforms Compatibility Matrix.
  1. On the top navigation bar, click Cloud Services, and then select Cloud Disks from the Storage menu.
  1. Click Create.
  1. Configure cloud disk parameters as described in Table-1, and then click OK.
Table-1 Configuring cloud disk parameters
Parameter
Organization
Select an organization. Only system administrators can select an organization randomly. Organization administrators and users can select only the organization to which they belong.
Owner
Select an owner. This parameter is available only for system administrators and organization administrators. The selected owner must a user that already exists in the system. A system administrator can select itself or a random user. An organization administrator can select itself or a random user in the same organization (users in suborganizations are not included). A user can select only itself.
AZ
Select an AZ.
Name
Enter a name for the cloud disk.
Storage Type
Select a disk storage type.
The default disk storage type Normal is defined by the system. If you select this disk storage type, the system places the cloud disk on a random storage pool in the selected AZ. To add disk storage types, see "Create a disk storage type."
Shared
Configure whether enable the cloud disk to be attached to multiple cloud hosts. Only CAS supports this feature. The provisioning type of a shared CAS disk is thick provisioning only and the disk usage is 100%. The default provisioning type of a non-shared CAS disk is thin provisioning.
Creation Method
Select whether to create a formatted empty cloud disk or create a cloud disk from an image. The latter contains data of the image. When you create a cloud disk from an image, the image cannot be an ISO image.
Disk Type
Select a disk type. To create disk types, see "Create a disk type."
Attach to Cloud Host
Attach the cloud disk to a selected cloud host after the cloud disk is created. To avoid failures of cloud disk detaching, make sure the selected cloud host has an operating system. (If the cloud host has no operating system, hot disk deletion will fail.)
To attach a cloud disk to a cloud host, see "Attach a cloud disk to cloud hosts."
Device Name
Specify a device name for the cloud disk. This parameter is available only after you enable device name configuration for the cloud host to be attached.
If you specify a device name, the system uses the specified device name to attach the cloud disk to the cloud host.
