On the top navigation bar, click Business Apps.
From the left navigation pane, select Microservices > Microservices Engines.
Click Create.
Configure engine parameters as needed, and then click Create.
Parameter |
Engine Name |
Specify an alias for the microservices engine. You can select a microservices engine by its alias when you create an application group. For more information, see "Create an application group." The alias is a string of 1 to 30 characters and can contain letters, digits, underscores (_), and hyphens (-). |
Resource Configuration |
Select a container cluster to provide an isolated working environment for the microservices engine. The system will automatically deploy the engine component container to the selected container cluster. The following cluster types are available:
Only services deployed in the selected container AZ or cluster can use the microservices engine. |
Access IP |
This parameter is optional. Enter an IPv4 address in dotted decimal notation. If you do not specify an IP address, the VIP is used. |
Parameter |
Engine Type |
Select Spring Cloud. |
Component Type |
Select a component type:
Spring Cloud native component configuration |
Version |
Available versions include Finchley.SR4, Greeenwich.SR1, and Hoxton.SR8. |
Engine Component |
Configure the registration center, configuration center, and API gateway settings. The registration center is required, and the configuration center and API gateway are optional. As a best practice, configure the configuration center. The available configuration center, registration center, and API gateway versions vary by engine version, as shown in Table-1. |
Nacos |
Engine Component |
Configure the registration center, configuration center, and API gateway settings. The registration center and configuration center are required and are selected by default, and the API gateway is optional. |
Instance Quantity |
Specify the number of registration center, configuration center, or API gateway instances as needed. More instances can improve system reliability but require more resources. |
Container Flavor |
Specify the container startup and operation limits. The startup limit cannot be higher than the operation limit.
Cluster External Port |
Manually specify or configure the system to automatically allocate the internal/external network port number for the engine component. Nacos supports gRPC and requires three ports to be opened. The system can assign ports automatically. If you choose to assign ports manually, you only need to enter the main port number, and the system generates the other two port numbers automatically, main port number+1000, and main port number+1001. |
Database and Middleware Settings |
Configure database and middleware settings for the configuration center of the Spring Cloud native component, registration center of Nacos, configuration center, and API gateway.
Table-1 Component versions supported by different Spring Cloud engine versions
SpringCloud engine version |
Registration center version |
Configuration center version |
API gateway version |
Finchley.SR4 |
Eureka2.0.9 |
Spring Cloud Config2.0.9 |
Spring Cloud Gateway2.0.9 |
Greeenwich.SR1 |
Eureka2.1.1 |
Spring Cloud Config2.1.1 |
Spring Cloud Gateway2.1.1 |
Hoxton.SR8 |
Eureka2.2.5 |
Spring Cloud Config2.2.5 |
Spring Cloud Gateway2.2.5 |
The microservices engine will create a registration center, a gateway, and a configuration center automatically. To view their internal access addresses and external access addresses, click the engine name and access the detailed engine information page.
