On the top navigation bar, click Resources.
From the left navigation pane, select Network > Network Planning.
Set the tenant (organization) network isolation mode. Only the VLAN mode is supported.
To edit the VLAN ID range for an egress, click Edit for the egress. On the page that opens, edit the VLAN range for the target egress.
Click OK.
