Application orchestration is mainly intended to provide one-click deployment of business application services. An administrator can plan the service deployment logic by performing the following task in a template:
Arrange software packages (image files, Jar, War, or Helm), container applications, cloud host applications, application groups, runtime environments (container permissions, service access configurations, or VMs), microservices engines (Spring Cloud or Istio) on the orchestration topology with simple drags.
Configure the dependencies between the resources by drawing lines.
Figure-1 Application scenario
