Namespaces provide a method to isolate resources between users in a cluster. Namespaces are isolated from one another, which means two namespaces cannot communicate with each other. If you specify a namespace in the application affinity parameters for application deployment, the application will be deployed to nodes in that namespace.
Namespaces management contains the following tasks:
On the top navigation bar, click Cloud Services, and then select Cloud Container Engine from the Container Service menu.
From the left navigation pane, select Clusters.
Click the name of a cluster.
Click the Namespaces tab.
Click Create Namespace.
Enter the name and description, and then click OK.
Click Update in the Actions column for a namespace.
Edit the namespace description, and then click OK.
Deleting a namespace will also delete its configurations, including PVCs, ConfigMaps, and secrets. Those configurations cannot be restored after deletion. Make sure you are fully aware of the impact of namespace deletion. |
Click Delete in the Actions column for a namespace.
