Add real servers to a real server group
A real server refers to a cloud host that provides services. When you add a real server, you can specify its weight based on the cloud host performance. You can add IP addresses for real servers.
You must create the elastic cloud host in advance. For more information about the procedure, see "Create or apply for a cloud host." In the current software version, you can add the cloud hosts that belong to the same VPC as the load balancer.
  1. On the top navigation bar, click Cloud Services, and then select Load Balancing from the Network menu.
  1. Click a load balancer name.
  1. Click the Real Server Groups tab.
  1. Click More Actions for a real server group, and then click Add Real Server.
  1. Configure real server parameters as described in Table-1.
Table-1 Configuring real server parameters
Parameter
Subnet
Select a subnet attached to the load balancer.
Back-End Port
Enter a service port number on real servers.
Weight
Set the weight of real servers. A listener distributes requests based on the weight of real servers. A server with a higher weight receives more traffic than a server with a lower weight.
Enable Real Server
Select whether to enable the real server. If you do not enable the real server, the listener does not distribute traffic to the real server.
Host
Select cloud hosts. The system displays IPv4 or IPv6 cloud hosts for IPv4 or IPv6 load balancers.
You can enter a cloud host IP address to filter target cloud hosts.
Click  before the IP column header to sort the cloud hosts in ascending or descending order.
IP Addresses
Specify unused IP addresses within the subnet. Each IP address can be added only once to a real server group. In the same real server group, you cannot add the same IP for two real servers that use the same port number.
  1. Click OK.
