Create a listener
After creating a listener, you can also configure the real server group and health check settings for that listener.
Create a listener
  1. On the top navigation bar, click Cloud Services, and then select Load Balancing from the Network menu.
  1. Click a load balancer name.
  1. Click Create on the Listeners tab.
  1. Configure listening parameters as described in Table-1.
  1. When you configure listening parameters, use the restrictions and guidelines in "Restrictions and guidelines."
Table-1 Configuring listening parameters
Parameter
Protocol
Select a protocol which the listener listens to. Options are TCP, HTTP, HTTPS, and UDP.
Source Network Address Translation
Set whether to translate source IP addresses of packets into the virtual service IP address.
Real Network Address Translation
Set whether to insert real source IP addresses of packets to the HTTP extended field after the SNAT is performed. This field is displayed after you specify the protocol as HTTP or HTTPS.
Port Number
Enter a port number on which the listener listens for requests from clients.
Idle Timeout
Set the TCP idle timeout. If a client has not sent any TCP packets to real servers when this timer expires, the TCP session of the client ages out.
CAUTION CAUTION:
For F5 LB devices, you must configure this parameter.
Server Certificate
Specify the server certificate uploaded by the organization. To create a certificate, click Create Certificate. For more information, see "Create a certificate." This field is displayed after you specify the protocol as HTTPS.
Enable Connection Limit
Set whether to enable connection limit. By default, connection limit is disabled. You can enable connection limit and set the maximum number of connections.
  1. Click OK.
  1. After the listener is successfully created, click Create in the dialog box that opens to create a real server group, or click Cancel to finish.
Create a real server group
  1. After a listener is successfully created, click Create in the dialog box that opens. Alternatively, create a real server group on the Real Server Groups tab as described in "Create a real server group."
  1. Configure real server group parameters as described in Table-2.
When you configure real server group parameters, use the restrictions and guidelines in "Restrictions and guidelines."
Table-2 Configuring real server group parameters
Parameter
Name
Specify a name for the real server group.
Listener
Select a listener with which the real server group is associated when you create a real server group on the Real Server Groups tab. By default, the listener created at the previous step is selected.
Default Configuration/Custom Configuration
Select Custom Configuration to configure the LB algorithm and enable session persistence. By default, weighted round robin algorithm is selected and session persistence is disabled.
LB Algorithm
Weighted Round Robin
Assign new connections to real servers based on load weight values. The system assigns more connections to a real server with a larger load weight. This algorithm typically applies to short connection services, such as HTTP.
Least Connections
Always assign new connections to the real server with the fewest number of weighted active connections (the total number of active connections divided by weight). This algorithm typically applies to long connection services, such as database connection. This option is available after you select Custom Configuration.
Source IP
Hash the source IP address of user requests and distribute user requests to different real servers according to the hash values. This algorithm allows a fixed real server to process the requests of a specific client. This option is available after you select Custom Configuration.
Session Persistence
Set whether to enable session persistence. This feature allows a fixed real server to process the requests of a specific client. By default, session persistence is disabled. This field is available after you select Custom Configuration.
Session Persistence Type
APP_COOKIE
Identify clients by creating different cookies for app sessions. Requests from the clients with the same cookie are processed by the same real server.
HTTP_COOKIE
Add a tag to the HTTP response for the first connection of a client. Requests with the same tag are processed by the same real server.
SOURCE_IP
Hash the source IP address of user requests and distribute user requests to different real servers according to the hash values. Requests sourced from the same IP address are processed by the same real server.
Cookie Name
Enter an APP cookie name if you select APP_COOKIE as the session persistence type. Make sure the cookie name matches that configured for the application on the real server.
  1. Click OK.
  1. After the real server group is successfully created, click Create in the dialog box that opens to create a health check monitor, or click Cancel to finish.
Create a health check monitor
  1. After a real server group is successfully created, in the dialog box that opens, click Create. Alternatively, create a health check monitor on the Real Server Groups tab as described in "Create a health check monitor."
  1. Configure health check parameters as described in Table-3.
When you configure health check parameters, use the restrictions and guidelines in "Restrictions and guidelines."
Table-3 Configuring health check parameters
Parameter
Name
Specify a name for the health check monitor.
Health Check Protocol
Select a protocol for health check.
For HTTP or HTTPS
HTTP Method
Select an HTTP method.
URL
Enter a URL for accessing real servers.
Expected Response Code
Enter the HTTP response code that real servers are expected to return. The response code contains the status of the real servers. The first digit of the response code identifies the response code type. The function of second and third digit is not defined.
Expected Response Contents
Enter the HTTP response contents that real servers are expected to return.
Check Interval
Set the interval between two consecutive health check operations.
Timeout
Set the health check timeout timer.
Maximum Retries
Set the maximum number of consecutive health check failures. If this limit is reached for a real server, the system stops distributing traffic to it.
  1. Click OK.
