Download an application package
To use an application package in an environment other than this system, download the application package. You must select a version when you download an application image.
  1. On the top navigation bar, click Business Apps.
  1. From the left navigation pane, select Software Center > App Repositories.
  1. Click the Private Repository or Public Repository tab.
  1. Click Download in the Actions column for an application package.
  1. In the dialog box that opens, select an application package version, and then click OK.
