On the top navigation bar, click Business Apps.
From the left navigation pane, select Software Center > App Repositories.
Click the Private Repository or Public Repository tab.
Click Upload Application Package.
Configure the parameters as required.
Table-1 Configuring application package upload parameters
Parameter |
Repository Type |
Package Name/Alias |
The name of an application package cannot be edited after it is being uploaded. The alias can be edited at any time. You can use aliases to search and filter application packages. If you do not specify an alias, the system uses the application package name as the alias by default. |
Package Version |
Specify a version number for the application package file to upload. When you deploy or download an application package, you can use the version number and description to select an application package version. If the application package to upload has the same name as an uploaded application package, their version numbers cannot be the same. |
Package Category |
Select the category to which the application package belongs from the categories created in "Create an application package category." If the application package to upload has the same name as an existing one, the system identifies the category of the application package automatically. |
Icon |
Upload an image that can identify the application package easily. |
Description/Version Features |
Add a description and version features. |
Click Next.
Select an application package category based on the application package type. You can upload one War package, Jar package, or Zip file at a time, and the size cannot exceed 4 GB. The Helm packages or traditional software packages to upload must meet the requirements in "Create an application package."
Select Upload from Local or Remote Gateway Address.
Upload from Local—Drag an application package file to the gray area, or click Select File to select an application package file, and then click OK.
